2x4 front ROTORS???
However, I will be getting a conversion kit for the next time I change them.
Can't turn them on a lathe, so I had to buy new ones. The backs can be turned though.
I am assuming you bought the conversion kit? I still have the once piece rotors.
No it doesn't but it wouldn't hurt to put a very light film of grease on the spindle shaft. When I replaced a front wheel bearing on my SIL's '07 F-150 there was a little bit of rust on the shaft from a small amount of water getting past the seal. Don't grease it like it was a bearing though because it needs to not turn on that shaft. 295 ft. lbs. of torque should keep it from turning, but if it did you'd be buying a new spindle.
"cheers"
