How many idler pulleys do I need?
I have a gatorback belt on the way. I want to replace the belt tensioner and idler pulleys but I see several different ones available to purchase. How many are there? Are there one smooth and one grooved?
2005 F150 XLT with 5.4 and A/C
Thanks for any help
Thanks for any help
Not that it matters, but why would you replace them unless there is an issue? The belt is preventive maintenance, but the idlers/tensioner is probably fine unless you suspect a problem.
Should be able to remove the belt and spin by hand and tell if a bearing is going bad. Normally they don't have to be running to hear it.
Yes.
