Fuel gauge surprise today!
Old Feb 29, 2012 | 08:53 PM
F1Fitty98's Avatar
Hey guys, just got my truck in Dec '11. Had 86,500 on it. Already noticing the plugs definitely need to be done, gonna do the coils too, due to some chugging at times on the low end when gettin back on the gas. I think i got this ironed out in a different post...
Today, I had roughly 1/4 tank of gas, stopped to fill all the way up. I start my truck up....and my fuel gauge doesn't move up a hair. Sooo, im thinkin either the sensor is stuck, or i was pumping air, lol/jk
So, as I am driving to work, I notice the gauge slowly creeping up when I am moving. When I stop it doesn't seem to move. After approx. 6mi to work, and when I arrive it was around 3/8th tank. I turn truck off and back on to see if it'd go, wouldnt. After work I drove and additional 10-12mi and it finally gets up to the full mark.
I am not 100% sure how the sensor/transmission of the signal gets to the gauge with these trucks, as I am new to Ford trucks. Anyone ever had this happen and figure out why? I am afraid it may never come up one time.
Also, the mechanics behind the sensor/delivery of signal, as to diagnosing the problem if no one has had this happen. Or is this "normal" sometimes?
Lil info, it is Michigan, so winters can be cold. It was rainy this morning, some freezing rain. Truck had a light coating on it this morning of ice that easily brushed off, for example. Though it was about 32*F when i left my house. Truck is a 2007 F-150, XLT 5.4L, S-crew, 4wd.
Old Feb 29, 2012 | 09:16 PM
4.6 Punisher's Avatar
That usually happens when you fill up and have the engine off, but the key in the "run" position. Happened to mine to and it corrected itself well before the next fill up.
Old Feb 29, 2012 | 10:00 PM
F1Fitty98's Avatar
Really don't think I had it in the run position, but I guess it may of been by mistake. If I remember correctly, I had the keys in my pocket when I ran into the station.
Old Feb 29, 2012 | 11:08 PM
JoeyStags's Avatar
I had that happen to me once before like a year ago and hasnt happened since.... i wouldnt worry about it unless it happens alot more frequently
Old Feb 29, 2012 | 11:29 PM
MTM Ford's Avatar
Happened to mine a few months ago too and I had the keys in my pocket when I filled it up. That's the only time it's happened to me also. It was back to normal though by time I got home which is less than 1 mile from the gas station.
Old Mar 1, 2012 | 12:09 AM
2wdoffroading's Avatar
Mine has done this exact thing as well. Don't worry about it. Never happened to me again
Old Mar 1, 2012 | 08:01 AM
Remingtonry's Avatar
My explorer did this to me once shortly after I bought it and then never again, haven't had that issue with my truck.
Old Mar 1, 2012 | 03:02 PM
06bluemeaniexl's Avatar
Mine does it occasionally
Old Mar 1, 2012 | 05:25 PM
F1Fitty98's Avatar
Ok, thanks all, was just makin sure I shouldn't be looking into a fix here before it was permanent or something. Had a car like that once when i was 16, lol...had to figure out how much gas i had by mileage, LOL!
Old Mar 2, 2012 | 04:28 PM
kcward's Avatar
My truck does this intermittently...last time it happened was a couple of weeks ago. It took 2 days for the gauge to go to full, then the gauge came down very slowly as the fuel was consumed (150 miles before it even moved off of full...not possible on this truck as it only gets 300 miles per tank normally).
Regards!!
Old Mar 4, 2012 | 12:15 PM
Jolly_Green_Giant's Avatar
My truck will do it anytime I fill up the tank while the truck is running. I've never had it happen as long as the truck is turned off however.
