Bigger tires create vibration??
Like others have said a road force balancer is the way to go. I had vibration issues when I first got my 20's on.
Just make sure it is a reputable shop that knows what they are doing. I went to one place that told me all of my new tires were out of spec. I knew that something was wrong so I found another shop that had the road force machine and they got them balance correctly without issue.
If there is a place around you that sells aftermarket wheels (20's, 22's, 24's) you might ask them if they do it or who to use. I am sure that they have experienced issues. The larger the wheel/tire combo is the more likely you will need road force from what I understand.
Okay I just called the local ford dealership. They have and can do the road force test for $49.99. But I'm a little hesitant to do this since I experienced the same exact vibration at the same speeds with both a brand new set of Nittos AND a brand new set of BFG's. Seems to me (I'm NO pro) that if it was a tire or balancing issue that one of the two new sets would not make a vibration?
Would you guys go do the test or look elsewhere for what's making the vibration?
Thanks again for your input!
Someone else may need to confirm this but I am pretty sure the road force machine would also be able to tell if your wheel was out of round or the problem.
If it does it might be worth the $50.
Well, just got the road force balance and they say the tires are great and they were a little off balance. Paid the $50 and about half a mile from the dealership I feel it's still vibrating! Aaargh & uuugh!
I dunno what tha F to do...
Without spending $400 for a mech to look over everything, what do y'all think I should look into next? Tie rods, ball joints, drive shaft, shocks or struts? Does the 06 even have struts? lol
Sorry to keep asking questions but this is driving me crazy!
Yes Sir, that's the good thing about dropping that $50. One less thing it could be...
Unfortunately someone will have to look at the suspension parts to determine if they are good or not.
One question. You stated the vibration was in the steering wheel and pedal. What about seat of the pants? One thing these earlier models, especially 04 and 05 had a problem with was the e-brakes. They would rub, heat everything up and cause one heck of a vibration. If yours was seat of the pants and only after driving a while I would suspect that. Otherwise more likely something in the front. Also have the u-joints checked. They could cause vibration also.
As you have already found out, vibrations can be a bear to find.
It has coilovers. You can replace the shocks without replacing the springs. Are the shocks original? If so they should be replaced no matter what. Rears are easy to do, but on the front, the coilovers have to be pulled and the springs compressed.to remove the shocks.
From what I can tell I feel it in my steering wheel, pedals and floor board. Don't recall feeling it in the seat any. Also, it's not after warming up. I'm on a 2 lane hwy about 2 min after leaving my house and it's vibrating there.
What's throwing me off is this started exaclty when I went from 285/17 tires to 305/17 tires. So I keep thinking what could have happened when moving up to a an inch wider and an inch taller? Is there some kind of joint or axle that would have adjusted from the raise in tire size it's is not lined up correctly now?
First, thanks for your time here! I learned just about everything I know about my truck on this forum so please excuse my ignorance!
Wow, bummer. I would have bet on a balanced wheel / tire with a high road force number. On the bright side, you've now eliminated one of the easiest variables from the equation.
Took truck to discount tire and had them move the front tires to back and back to front. Still vibrating... So I drove it straight to the dealership. I'm now waiting while the dealership mech is trying to find the issue.
