2007 saleen harley 90k service-$$$ please help
Old Feb 13, 2012 | 12:48 PM
SHURST's Avatar
Could someone with greater knowledge than myself confirm a quote i got on maintenace. The guy i talked with is ford all the way and knows his stuff.
I got a quote of 1350 for engine flush, radiator flush, thermostat, plugs, boots, fuel filter, oil change(fully syn), saleen blower maintenace and oil, and o2 sensor.
What do you think guys?
Old Feb 13, 2012 | 12:51 PM
What about the transmission?
Old Feb 13, 2012 | 12:54 PM
SHURST's Avatar
I asked about transmission when i talked to him and he said he'd look at the fluid first.
Old Feb 13, 2012 | 01:02 PM
It's recommended to change the fluid at 100,000 under normal usage. More often if you tow.
Old Feb 13, 2012 | 01:05 PM
SHURST's Avatar
I don't tow at all, truck has 85k. Is that total about right though? He said he called saleen and got the right plugs and other parts
thanks for replying
Old Feb 13, 2012 | 01:08 PM
I have no idea about what service of a super charger shoud run, but a plug change would be about $350, a coolant flush about $150.
Old Feb 13, 2012 | 01:28 PM
SHURST's Avatar
Ok, sorry forgot to mention new serp. Belt too. Its a high dollar truck so i want it kept up, saleen does recommend a service to the blower at this milage.
Old Feb 14, 2012 | 03:14 PM
Electron-Jack's Avatar
Sounds like a decent deal considering the plugs alone can be that much if all 8 break. I would have him remove the engine flush cost and skip it since your more likely to end up with VCT and phaser issues after the flush. Other than that it's a resonable deal if your not doing it yourself.
Old Feb 20, 2012 | 07:16 AM
SHURST's Avatar
Mind my ignorance, i'm not familiar with vct or phaser issues, could you explain? Thanks
Old Feb 20, 2012 | 09:08 AM
FATHERFORD's Avatar
With labor/parts/fluids that's about right.
Changing the thermostat is going to be a big job as I think the blower has to be removed to get to the cross over to remove the thermostat.
