Coolant question
Old Jan 10, 2012 | 11:35 PM
BlueOvalFitter's Avatar
Question Coolant question
Anyone here use Super Tech coolant or Prestone All Makes All Models coolant in their F150 that calls for Ford Gold?
Old Jan 11, 2012 | 10:22 AM
fatty4x4's Avatar
I use Zerex G-05 which is compatible with Ford Gold coolant. Bought at walmart.
Old Jan 11, 2012 | 10:28 AM
Smile
Thanx for replying fatty4X4. I know that Zerex G-05 is the same as factory Ford Gold,but i'm looking for people that have used any of the all makes all models coolant without problems. I'm going to call local radiator shops near me and get their input.
Old Jan 11, 2012 | 10:41 AM
leopold's Avatar
I was told by both a independent shop and the people at my NAPA store not to mix different coolants.
Old Jan 11, 2012 | 10:47 AM
Exclamation
I don't intend on mixing them,I want to use one brand.
I just called 3 local radiator shops and they all use the AMAMs coolant.I got a history lesson on coolant from one owner that has had a radiator shop in his family for over 52 years! Oh,and he said ST will work just fine.
Old Jan 11, 2012 | 11:08 AM
SoonerTruck's Avatar
Coolant is coolant as long as it's the same type. You can get the 5-yr stuff which is usually orange, or you can get the regular stuff which is usually green. Just don't mix the two or you end up with sludge. If you fully flush the orange stuff, you can go back in with the green.
Old Jan 11, 2012 | 11:32 AM
Thumbs up
SoonerTruck,do you own a radiator shop? I ask this because your answer is the same as most of the ones I called about this subject.
One shop owner said he uses Advance Auto brand coolant and buys it by the 55 gallon drum.
Old Jan 11, 2012 | 01:34 PM
I do not, but it has been the advice I've recieved from any shop I've dealt with. I also has the misfortune of seeing a friend's vehicle which had the greenish-brown mixed coolant in it after an emergency repair (not a cracked block/head gasket issue). I believe even the manufacturers advise not to mix coolant types, but I could be wrong.
However, I've never done a chemical analysis between the different types, so I can't scientifically verify that they are signicantly different; it's all glycol-based either way.
Old Jan 11, 2012 | 02:00 PM
Thumbs up
I was just kidding ya about owning a radiator shop because the reply you gave was the same as the answers I was getting from shops.
And,what I quoted you here was the same thing they were telling me also.The shops said the coolants are all glycol based but only use dyes to distinguish one make from another.
