Help!!! LEAK
Old Dec 22, 2011 | 07:09 PM
bigdog87's Avatar
Help!!! LEAK
Well, thing that caught my eye was that my subwoofers were not working.. went and pulled off the back seat, to notice the back seat/the amp, and back window were all dripping with water.. What's up with this? I've heard of the 3rd brake light leak, I searched it and couldn't find anything on it.. Any ideas, is their a seal that can be replaced? Is it possibly my rear window?? Any help would REALLY be greatly appreciated!
Old Dec 22, 2011 | 07:14 PM
3rd brake light leak is common on these years of trucks. I had good luck siliconing mine on but others have used better weather strippping with success.
There's lots of threads on this subject.
Old Dec 22, 2011 | 07:15 PM
EsJayEs's Avatar
Have a buddy spray the back of your truck with a hose and look for where the water is coming from.
Old Dec 22, 2011 | 07:17 PM
bigdog87's Avatar
Would silicone prevent the 3rd brake light from being able to come off?
Old Dec 22, 2011 | 07:20 PM
It will definitely make it harder to get off. If that's a worry then go the other route and create a new seal out of better weather stripping.
Old Dec 22, 2011 | 07:26 PM
bigdog87's Avatar
Yeah, need to work on it tomorrow and replace that seal/gasket.. I'm sure it's dry rotted, from being under a tree/in the sun! Thanks guys
Old Dec 22, 2011 | 07:28 PM
Yeah the stock seals are crap. Like EJS said have a friend hose down the back first from all angles to verify.
Old Dec 22, 2011 | 07:30 PM
bigdog87's Avatar
Yeah, we honestly probably had a solid 4-5" of rain today.. Not slow and steady, EXTREMELY heavy.. Planning on fixing it tomorrow before I head into work. Thanks guys
Old Dec 22, 2011 | 07:56 PM
Cool.
Mine is currently leaking but it's got a crack in the lens after inspection. Have it taped up all ghetto like, can't fix it right now because I have nobody to help me get the fiberglass lid off the bed.
I backed in and parked it on my upsloping driveway a few weeks ago and I had water coming down my windshield from the leaking 3rd brake light. It traveled down my headliner, pretty crappy to see. After that episode I taped it up. I'll fix it during the break.
Old Dec 23, 2011 | 12:35 PM
bigdog87's Avatar
Just went, took the 3rd brake light off. Did not show any signs of the sealing being bad.. But what I did discover is a small crack on the right side above the passenger side bulb..In there I located water droplets still in there, and also water droplets around both screws? I still have water puddled up in the back at both the passenger and driver side, but not in the middle? Suppose it's leaking on both sides and running down there? Last night when I went out, and I did notice water drops around the top of the rear window, not in the roof line just around the seal of the window? Could it be the rear window causing significant leaking? I'm trying not to say "hose down" the rear, because I do have hundreds of dollars in electronics back there and don't REALLY want to have to remove them.. Thanks.. Also planning on ordering a new 3rd brake light as well.
Old Dec 23, 2011 | 12:45 PM
fatty4x4's Avatar
Cool.
Stealth, I also have a tonneau. What I do to access the brake light is stand on the backdoor sill on one side to remove one screw then go around to other back door and do the same. Way easier than removing the cover.
Old Dec 24, 2011 | 09:59 PM
Some guy invented these things called ladders Will, you should try one out
That's what I do with my fiberglass tonneau
Old Dec 24, 2011 | 10:45 PM
MTM Ford's Avatar
Ya, but you'll scratch the paint.
I did mine the same way fatty4x4 does.
Old Dec 25, 2011 | 12:02 AM
bigdog87's Avatar
Good news guys.. With that leak, I fried my amplifier
