Leveling 2007 F150 2wd
Old Nov 6, 2011 | 08:11 PM
F1502wd2007's Avatar
Hey everyone i'm trying to lift up my truck enough to fit some 33in Nitto Terra Grapplers and before i buy anything and put it on myself I want to make sure it will look good with my 2007 f150 2wd. Please post pics of leveled 2wd trucks only and comments on what i should do.
Old Nov 6, 2011 | 09:03 PM
Bonanza's Avatar
I have an 07 crew cab. The 2" level kit worked perfectly, and was easy enough to do in a driveway if you have the right tools. Should be all you need. Sorry I can't post pics though, a quick search will do the trick.
Old Nov 6, 2011 | 09:20 PM
06bluemeaniexl's Avatar
Search tool is your friend.
If you're looking to do a level, I'd recommend the Rancho Quicklift Loaded (model #RS999909) struts. They're an entire assembly ready for install. They lift the front up 1.75 to 2" without needing spring compressors and without using the metal blocks or spacers. These should allow a 33 x 12.5 tire.
Old Nov 6, 2011 | 09:37 PM
samoan_pride43's Avatar
I used the Rough Country 2.5" leveling kit and with 1" rear and new shocks. Did it in the driveway with pretty much all the tools I had. Took about 3 hours to complete. I cleared 35x12.5x17 Pro Comps without any rubbing. Good luck with your mod.
https://www.f150online.com/forums/me...0&ref=gnr-next
Old Nov 7, 2011 | 12:38 PM
Thanks, i think i'm gonna go with a 2.5 leveling kit in the front and either a 1 inch or 1 1/2 inch blocks in the rear. Samoan, is your truck a 2wd? Cause i know it makes a difference on how the truck will look and if you have any pictures please post.
Old Nov 7, 2011 | 12:59 PM
Coskid's Avatar
I know mine is a 4x4 but it has everything you plan to use so I figured I would share the picture anyway. 3" Front kit, 1" rear block, with 285/65/18's Nitto Terra Grapplers.
Old Nov 7, 2011 | 06:36 PM
Yea my truck is 2wd and sits just as high as a stock 4wd now. All my pic are in my albums
Old Nov 7, 2011 | 08:50 PM
Note: my driveway is on a slope so it make the front look lower then it really is.
Old Nov 7, 2011 | 09:12 PM
evil05f150's Avatar
you can run 33" on a 2wd with out doing anything.
Old Nov 8, 2011 | 12:29 AM
Nettershakes's Avatar
Old Setup:
2.5" Topguncustomz level
285/70/17 Firestone Destination A/T
