Carson Airhorn Install Question.
Old Oct 20, 2011 | 12:04 AM
Drumdog's Avatar
Registered User
I am thinking about installing this "airhorn" in my truck. I am hoping some of you are wiring gurus and can answer a question for me. I am pretty sure that the RED wire on this unit can be hooked up to the regular horn hot wire between the relay and the factory horn itself. Am I correct in saying this? If this is the case, what color will this wire be? Thanks in advance for any help and your understanding that I wasn't sure where to post this.
Here is a link to the install .pdf for the unit.
http://www.carson-mfg.com/pdf/HA-150-10_Manual.pdf
I am replacing the factory horns with this device. I want them to operate using the horn ring and not a separate switch.
Thanks again!
Old Oct 21, 2011 | 12:45 PM
Culprit1384's Avatar
Yes you can as i have done so before.. For the wire color either go on the12volt.com or bulldogsecurity.com
Old Oct 25, 2011 | 11:47 AM
Drumdog's Avatar
Registered User
Thank you for the reply. I will check those sites out!
