Leveling Truck
Old Oct 9, 2011 | 08:15 PM
nagshead1's Avatar
Leveling Truck
My 04 Lariet 4WD Supercrew rear is higher that most similar trucks I have seen. A friend mentioned I may have an extra leaf spring. I count 4 leafs. I would like to level out. Any suggestions?
Old Oct 9, 2011 | 08:28 PM
alex7191's Avatar
a leveling kit
Old Oct 9, 2011 | 08:41 PM
atr04screw's Avatar
You can either raise the front end with a leveling kit or lower the rear with either drop shackles or removing the rear blocks. You can get leveling kits in 1.5", 2", 2.5" and 3", depending on if you want it perfectly level or if you want it to still have some rake, and you can get them for about $70. Or you can take the rear blocks out for free and it will lower the rear about 2" and level it out.
