Flex fuel Qs help
Go to Ford's Fleet website and put in your VIN number. It will tell you if it's a Flex fuel vehicle. Also, I might be wrong, but, I think 06 was the last year they made a 5.4L (if that's what your engine is) that WASN'T capable of E85. BTW, unless you get a ridiculous discount on E85 vs regular unleaded don't bother. My truck gets 9mpg running E85.
Ok cool did some research with the help from all of you and yes my vin's 8th character is a V and so now I can run E85.
So can you guys tell me what to expec, do you get better fuel millage? More horse power? Will it clean the carbon so I can change the plugs?
Thanks guys
Thanks guys
Fuel mileage sucks, I honestly thought the power was a little better. I do not know that it will help with the plugs, but its claimed to help the fuel system (injection). Here is a thread from way back when discussing power, it is a pretty good read.
https://www.f150online.com/forums/ge...ore-power.html
You will lose about 30% gas mileage and you will have a small increase in power.
The BEST way to clean the carbon is with a Motorvac or BG intake cleaning machine. The next best way is to add Techron to the gas and go out and drive it hard.
If you run E85, it's recommended to change your oil more often and use real gas every 3rd tank.
