Look what I found!
Look what I found!
Checking the local Craigslist every night has finally paid off. I just so happened to come across a Smittybilt Predator bumper guard on Monday night and I couldn't pass it up. Unfortunately it is chrome but that soon will change.
I know there is a few of you looking for one of these but I think I'm going to hang on to it (unless you can convince me otherwise
I also just got my mirror caps, tailgate and door handles PTM and got my fog lights painted black. Next mods - DIY Harley taillights (doing them tonight), smoked third brake light, and 09+ badges. New wheels & tires are coming this winter. Here are a few pictures
The only LED tail lights that I like are the smoked Recon's but I can't see myself dropping $270 on a set of tails. My stock tails are about to go in the oven for a little makeover in a few minutes
Ya, I just put that light bar on my truck about a month ago and thought that was it for up front but then I found this on Craigslist. I would have never guessed I would come across one on these for sale at anytime. The guy actually had it rigged up on his F-250 because he liked it so much
Do you guys think I should run three or four of the Hella lights on the new guard?
Here is a picture with 4 if you scroll down - https://www.f150online.com/forums/20...uy-here-2.html
Nice looking truck! You should consider adding some smoked Cab Lights to dress it up a bit more. Mine are sitting in my tool box waiting to be put on just can't block off the hours I need to get it done.
Thanks man, same to you! Your truck is what really made me went to get on of these and you are just the man I needed to talk to. I got a few questions about the guard. First off, how did you go about added four light? Did you get four light tabs welded on? Second, what diameter lights are those? Third, did you use the supplied mounting brackets?
Thanks!
Thanks!
I used flat stock,made four holes for the ligths and mounted it to the two tabs that the bar has.Yes, I used the stock mounting hardware but when I added the winch everything was reinforced behind the bumper.Hope this helps.
