Changing Interior to leds
Started changing the interior to leds. Finished the drivers master switch. Went with 5mm blue. Damn hard to make fit, will have to reorder in 3mm. Also, red may look better.
Question though, After a 20 min errand run, the buttons were warm. I've never had a led get warm, But this is the first time I've used the flat top wide beam. Do they run hotter? Using 470ohm 1/2 watt.
Decided red looked much better
Very nice! I def want to do this. Where did you get the LEDs? And was it difficult to install them? Maybe you could post a quick how to?
