Change Rear Bearings Now ABS light is stuck on!!!!
Change the rear bearings in my 2004-f150-5.4-3.73-fx4-Scab today. I changed them with the key switched on for the radio to play. I forgot completely about it still being hooked up to the battery. As I pull the ABS Sensor to fill the rear-end with gear oil while the key was switched on. So later on tonight I pulled the battery cable off and let it set for about 7-10mins. Got back in drove a while went off. Then before I could get home. The light appeared again.So what I am wondering since I broke the connection while the battery was still connected. Would that Short of the sensor??Also would this be the REAR ABS Speed Control Sensor-Title??? Any Hints????????
