Rough Country ABS Question
Subscribe
Aug 4, 2011 | 12:38 AM
So I just finished installing the 6" Rough Country lift on my truck last week. On the new knuckles, there doesn't seem to be a place to remount the ABS sensor wire. Since the sensor isn't hooked up, the ABS and brake light are on. The ABS light comes on at start up and the brake light comes on a few minutes later. My questioon is, for those of ya'll that have this set up, what did you do? Any help would be appreciated.
Here is a pic of the finished product...
Reply 0
Aug 4, 2011 | 09:08 AM
Wow, your truck looks fantastic! I love the chrome Monsters! As for the ABS mounting, what did Rough Country have to say? Come to think of it the ABS wire doesnt mount to any of the suspension components. There's a bracket at the frame side holding the sensor wire, but the other end of that wire should connect to back of the hub where the ABS sensor is located.
I need to go out to my truck to remind myself how this looks...
Reply 0
Aug 4, 2011 | 09:49 AM
On another note, I was just on the Rough Country website to see if I could help you and saw that the aft braces are not standard with your kit but are optionally available. Did you get these braces? I sure hope so as I don't see how the can be stable without them. If not, they are in expensive but should be a worthy upgrade.
Back to your issue...here is the install instructions: Click here for Install Instructions
Again, without actually looking at my truck, I am unclear as to what mounting point you were referring to.
Reply 0
Aug 4, 2011 | 10:48 AM
What size rim and tire is that?
Reply 0
Subscribe
