2006 ford f150 7700 series
Old May 17, 2011 | 02:07 AM
vandancouver's Avatar
hello. this is my first post on this forum. im looking for some more information on my truck.
i have a white 2006 f150, 7700 series.
all i really know is that its a "beefier" suspension, and has a slightly higher gvwr.
anybody know anything else?
i got wheels and tires put on it, which was a real pain to find wheels for it. only choice is to get them custom cnc machined or get lucky online and find some. i also got ceramic brakes and new rotors and calipers all around. they are all "one unit". i have flowmaster 40 series on it, a k&n drop in filter.
like i said, just looking for any other info on it. thanks alot
dan
Old May 17, 2011 | 04:00 AM
mtylerb's Avatar
dan
Is this one of the "Heavy duty payload" ones? 7 stud wheels, etc?
Old May 17, 2011 | 07:53 AM
kingfish51's Avatar
There is no such thing as a 2006 7700 series. Those ended in 03. Yours would be an 8200lb GVWR if it is the 7 lug axles. Main differences would be things like suspension, engine cooling etc.
Old May 17, 2011 | 04:07 PM
how can i find more information about it then. i thought it was a 7700 series because of the 7lug. so what is mine called then?
normal f150? or what is it then..
and what are the differences do you know at all?
Old May 17, 2011 | 04:16 PM
kingfish51's Avatar
It is called the heavy duty payload. You can see the GVWR on the door sticker. Not sure of any place that lists all the differences.
Old May 17, 2011 | 04:20 PM
CartsXJ's Avatar
I believe 4wheelparts and many others stock 7-lug wheels in different sizes. I know I've seen them on ebay.
Old May 18, 2011 | 12:34 AM
so i wonder if i got the heavy duty tranny, etc
Old May 18, 2011 | 12:55 AM
mtylerb's Avatar
The only reason I'm even aware of it is because I recently did the brakes/rotors/calipers on my truck. It took me a bit to figure out what the difference was between the rotors for "heavy duty payload" and regular ones was. Finally figured it out talking to a parts counter guy.
Old May 19, 2011 | 02:18 PM
Nope, you have the same 4R75E as all the 5.4 trucks.
Old May 23, 2011 | 05:50 PM
so what are the differences then? no one seems to know really.
Old May 23, 2011 | 07:45 PM
risupercrewman's Avatar
Rear axle, frame thickness, 7 lugs, springs!
Old May 23, 2011 | 08:14 PM
ConvertedMan's Avatar
There is a site that I posted a link to on here about a month ago, and now I can't find it. On this site you can put in the vin# and I believe it shows you window sticker. I do have it on my work computer and will try to post it tomorrow. Maybe it will help.
Old May 23, 2011 | 09:35 PM
sam1947's Avatar
Here is one of the sites : https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jul 28, 2011 | 12:37 PM
azmidget91's Avatar
anyone know if the 7lug trucks are the same height as a 6lug? i want stiffer coils but dont want to change the height
