05 intermittent starting issues
Just started this past week, cranks, but wont start. turn key off and back to start, then fires. some times I need a couple tries.
Is there a known issue I can look at first?
Besides fuel pump, what else could the issue be?
05 STX 4x4 - 4.6L - auto
Ken
Ken
Check this out>>>https://www.f150online.com/forums/ar...highlight=fpdm
AND
Get your battery checked also...
AND
I will check the FPDM this weekend, thanks for the tip!
As for the battery, It is original, so I have no problem with changing it. But it cranked over without issue, not showing signs of being weak.
I thought about a crank or cam position sensor... no clue where they are even located or how difficult to change. I know they usually are a cheap part.
I just bought the spark plug removal tool... I have yet to change the plugs on my truck... embarrasing to say, it has 199,000 miles on it.
Ken
Ken
Go get the battery load tested - Autozone can do that in the vehicle and it takes about 2 minutes, and it's free.
