4x4 problems
Old Apr 19, 2011 | 09:24 PM
Wert01's Avatar
Exclamation 4x4 problems
i just got a 04 f150 apparently with working 4x4 well its not and cant figure out what the problem is vie had it up in the air check the pump and made sure the actuator is engaging with a vacuum pump and check both lines at the pump and it moved freely both ways im really not sure where to go from here any ideas
Old Apr 19, 2011 | 09:56 PM
T case motor?
Or the IWE hub itself....
Old Apr 20, 2011 | 07:20 AM
60DRB's Avatar
I am not sure what you are talking about. I get that your 4x4 isn't working. What pump are you talking about? You say you checked the actuator was engaging- you're talking about the IWEs at the inner wheel hubs, correct? Bear in mind, I am old and need punctuation and complete sentences to clearly understand.
Q: When you engage your 4x4 do you get a "4x4" light on the dash? If not, you might try tapping on the shift motor (that's on the transfer case) with a non metallic item, like a hammer handle.
Q: Have you checked that all the vacuum lines are holding pressure? Also the two check valves- they should only allow air to pass in one direction.
A very common 4x4 problem is the older design solenoid failing due to water damage. That item is on the passenger side firewall behind the battery. The newer design has a plastic shield over the top.
Old Apr 20, 2011 | 11:54 AM
mkosu04's Avatar
Old Apr 22, 2011 | 12:20 AM
Wert01's Avatar
4x4
ok so bear with me im a not a mechanic so the pump i am talking bout is the vacump pump not from the hub itself i got 10 in on both lines the 4x4 light on the dash comes on every time now i didn't check the solenoids on the firewall the driveshaft can still be moved when i had it up in the air i did not check anything on the hubs but i also replaced a wheel bearing hub a month ago so im really not sure what else im looking for when i had it up in the air i had no power in the front tires the truck sounds like its in 4x4 but its not so the pump that is next to the case has a rod that pushes on a lever when i hook the vacumn up to it it moved freely both ways
Old Apr 23, 2011 | 06:15 PM
Wert01's Avatar
so if any one can help me i don't know if i am being clear enough about the problem any input would help thanks again
Old Apr 23, 2011 | 06:17 PM
Wert01's Avatar
its not the hub its the i believe its the case that is the problem
Old Apr 23, 2011 | 06:18 PM
Holy run-on sentences, Batman!
Sorry, I am of no help.
Old Apr 26, 2011 | 12:10 PM
mkosu04's Avatar
http://www.wikihow.com/Use-English-P...tion-Correctly
if you don't take the time to clearly explain the issue then why should we take the time to try and decipher your post and then help you?
Old Apr 27, 2011 | 05:22 PM
60DRB's Avatar
...I only speak/read actual English. I can't help if all I get is " text speak"... Laugh all you want to. State your issues clearly or I'm done here.
Old May 9, 2011 | 10:55 PM
Wert01's Avatar
ok i put the leaver in 4x4 when i do that i hear a small bang like its engaging into 4x4 but its not the drive shaft going to the front rear is very hard to turn so i believe it is engaging in the transfer case there is a small vacumn pump on the front rear i checked the vacumn lines coming out of that actuator and it goes both ways moving the leaver on the rear but its still not engaging should i be checking the iwe first or the rear its self thanks
Old May 10, 2011 | 08:29 AM
HighOn22's's Avatar
I'l help you out this time, but in your next post you need to use periods,comma's, CAPITAL letters and etc. if you want ayone to help you out. They were trying to tell you this in a nice way. By the way, I'm not of any help to this issue. I was reading through it to see what the fix would be to learn something new.
Originally Posted by Wert01
Ok, I put the leaver in "4x4". When i do that, i hear a small bang like its engaging into 4x4, but its not. The drive shaft going to the front is very hard to turn so i believe it is engaging in the transfer case. There is a small vacumn pump on the front-rear. I checked the vacumn lines coming out of that actuator and it goes both ways; moving the leaver on the rear, but its still not engaging. Should i be checking theIWE first, or the rear its self? Thanks
Old May 10, 2011 | 11:58 AM
mkosu04's Avatar
whats a "leaver"?
Old May 10, 2011 | 09:14 PM
60DRB's Avatar
I only speak English and German. I quit.
