Rubbing at full lock-need help
Old Apr 15, 2011 | 11:37 PM
rrozell's Avatar
Question Rubbing at full lock-need help
Just got back from having 6" kit put on. Now tires are rubbing fender corner(plastic piece on bottom of fender, not the front valance the piece on the fender closer to the cab.) what did you guys use to cut it? Has anyone else had this issue. Debating putting a 1" spacer on strut, any suggestions?
Old Apr 16, 2011 | 01:56 AM
StoveTop's Avatar
Yep, this is what happened to me when I changed my rims w/ 5.5" backspace with the current set up wtih 4.5" backspace. I added a 1" Daystar spacer on top of the strut. So not only did I get rid of the rub, I added more lift to the front. Instead of the 1" Daystar, get the 1.5" AutoSpring with the offset design.
