anyone else seen allot of junk in their trans pan when changing the filter?
Old Mar 27, 2011 | 01:36 PM
fivespeedsteed's Avatar
i dont believe in flushing either, ill just drop my pan and keep putting clean fluid back in. i might invest in a mag hitec or the factory one with the drain plug .
Old Mar 27, 2011 | 07:46 PM
risupercrewman's Avatar
Whats the Ford part number for the 5.4 3v trans filter?
Old Mar 27, 2011 | 08:15 PM
818F150's Avatar
Ya I want to do a transmission fluid replacement I bought my trucked used with no service records in the glove box. Im sure the ford dealership has the records it he took it in right?
By the way if he said he replaced a leaking axle seal does that mean they replaced the differential fluid?
Old Mar 27, 2011 | 11:22 PM
probably.
i have no idea the motocraft part number, i just use proking filter and gasket kits from advance. fk266 i believe.
so do these transes get build up in them faster becuase they shift slow? anyone run a gryphon or edge for 30k and had a cleaner magnet because of it?
also, a word of caution, i did my transfer case at 60k, the interval on that is 60k if you offroad allot, and i dont really offroad allot, but my fluid in there was nasty. if you have never changed your transfer case fluid and your north of 60k i would defiantly do it. 2 quarts of dex3/merc is all it takes. and the t case skid on fx4s and equipped lariats will make it drip out of most of those holes in the bottom of it
Old Mar 28, 2011 | 08:39 AM
reamer1976's Avatar
Had an 04 S-crew. 165000 miles on it, ran, shifted great, NEVER touched the tranny.
"some things are better left alone?
Old Mar 28, 2011 | 09:00 AM
My dealer I refuse to go to for Tranny service... they won't drop the pan, just flush it. Heck it's a contract with an outside company too. Screw that Found a Transmission shop one town over I'll be checking out shortly
Old Mar 28, 2011 | 12:03 PM
ab46501's Avatar
I've got about 74000 on my truck now and had the tranny fluid exchange done last year around 65000. I probably need to change the transfer case fluid as well. I have found several post that say its fairly easy but none that describe where the fill and drain holes are?
Old Mar 29, 2011 | 11:55 AM
the fill and drain holes are easy to find, the transfer case is behind the trans in the center of the truck, it has a big window motor lookin thing on it. the drain and fill holes are right there, thats the back of the t case. pull the fill plug first, then the drain, so if the fill is stuck you wont drain the fluid out and then be left with no fluid in there. only takes about 2 quarts of dex3/merc trans fluid
Old Mar 29, 2011 | 12:02 PM
ab46501's Avatar
Ok! Thanks for the info!
Old Mar 29, 2011 | 06:55 PM
Svets96's Avatar
Creeping up to 50k, a buddy of mine said my tranny fluid needs replaced along with a new filter. So by April this should be getting done. Cant wait.
Old Apr 15, 2011 | 10:23 AM
anyone changed their filter and fluid after using a gryphon or edge programmer? im wondering how i can cut down on the amount of clutch material i have hanging out. most transes i do arent as bad as mines been.
does anyone install factory tech separator plates ? i know of that one guy that has the 8 foot bed truck that did that, is a tuner sufficient to get the trans shifting correctly and not tearing up clutches?
Old Apr 15, 2011 | 10:42 AM
XPerties's Avatar
I have Amsoil on order and new tans filter sitting next to me. I just ordered a Magnefine inline filter and will be doing a fluid exchange myself in a week. Ive been running a Gryphon for the past year and half on Tune 1 Tow so I'll let you know how it looks when I do the job.
Old Apr 15, 2011 | 12:01 PM
great. id be glad to hear it.
your just running on 1? trans only?
have you used level 2?
Old Apr 15, 2011 | 12:21 PM
XPerties's Avatar
Yes, I used Level 2 performance for about 4-5 months and then switched to tow since.
Old Apr 15, 2011 | 11:43 PM
HamRadio's Avatar
You will like the Amsoil! I did mine at 49K along with a filter change. Old stuff was clean and a little on the magnet. Out of that 49K about 30K was towing my TT. I run an early tuner with Troyer tunes for towing and perf. Last week at 60K I did a new filter and a new MagHytec pan. Fluid looked like new. The MagHytec added about 6 more qts than stock. So I'm good to go it seems. I also run a second cooler in line with the stock towing cooler. I monitor the tranny temps and the fluid return temps. My TT weighs in on the scales loaded at 6270#. I did 4200 miles on one trip last year to Washington, Oregon and Idaho from Cal and got an overall mileage of 11.6.
We are off to Knoxville TN in about two weeks and I know the gas is gona kill me. Oh and I do have the Heavy Duty Package with an 8 foot bed and a 10.5 inch sterling 4.11 rear end.
