Updated 5.4 with tune and WOW
Old Mar 14, 2011 | 05:13 PM
mSaLL150's Avatar
Originally Posted by rrozell
Funny you say that, I wondered the same thing. I asked around for a long time before I began this project and all said that as long as I had the tow package gears (373) that I would be fine. I know that a larger gear ratio will be better but a ton a people are running the same set up. 4.56, do you really need to go that high? Is it that much better than the 4.10's? I have a 2x4 screw and it will never see off road. Just for looks, I know its a disgrace but its what I have.
Where in CA are you located? If you are in Socal or the valley and are only on flat land, the 3.73s will be sufficient for the 35s. If you are in the mountains of NorCal or go to Tahoe at all, you will really want taller gears as the tranny struggles uphill with the larger tires.
I called the dealer and had them run the vin# to give me the gear ratio and its 3.73. The tuner is set to 3.55 from SCT so I switched it to 3.73 to match what I have. What year and engine size do you have. Mine is 08 5.4l
Never mind I see its an 05 which I am guessing is a 4.6l?
He is probably correct, but check the door tag, see what the axle ratios says.
Old Mar 14, 2011 | 05:40 PM
rrozell's Avatar
Doortag code--- B6 : 3.73 LS (limited slip)
For all the non-believers
rrozell's Avatar
I am in San Diego. Pretty flat, small slope grades
Old Mar 14, 2011 | 05:54 PM
rrozell's Avatar
I never have kept the stock gears in my mustangs so I am sure I will end up changing these also.
Will 4.10's be sufficent? I even just saw a 4.30 which may be a happy medium. I am worried about the 4.56's bc I do 90% of my driving on the highway at 75-80mph.
Old Mar 14, 2011 | 06:20 PM
drewsbu's Avatar
1 Full tank of 91 fuel you are planning on using will cost more than a custom tune.
Old Mar 14, 2011 | 06:26 PM
rrozell's Avatar
That is a valid point! Especially here in SD with 91 going for $4.10 gallon
Thanks, why didnt I think about that?!?
Old Mar 14, 2011 | 06:34 PM
rrozell's Avatar
But if I am paying for a custom tune why not get it to include 91 octane to get the most power out of the motor. Bigger bang = more HP
Old Mar 14, 2011 | 07:31 PM
kobra_commader's Avatar
Get at least 4:10s I got 3:73s wit 35s and I think I'm goin with 4:56s. 3:73s just ain't enough
Old Mar 14, 2011 | 08:05 PM
mSaLL150's Avatar
The change from 3.73 to 4.10 wont justify the cost. Do 4.56s if you decide to drop the cash. I would try the 3.73s for a while though, i think you will be okay on flat ground as long as you have custom tuning.
Old Mar 14, 2011 | 08:38 PM
With 2wd, 4.30's are an option and would probably be your best compromise.
