2008 FX4 hub assembly
Old Mar 11, 2011 | 09:31 PM
Cappycpt's Avatar
Need to know torque specs for spindle nut and what grease and how much to use for replacing driverside Timkien hub assembly. Complete unit bearings already inside?
Old Mar 12, 2011 | 06:43 AM
AUBIN's Avatar
was it making any noises before you changed it? my trucks making some front end noise , only when im moving and its been getting worse, not sure if its a bearing or a brake issue, hope its nothing serious. was your hub making noise?
Old Mar 12, 2011 | 10:10 AM
greencrew's Avatar
The book says 27Nm (20 lb-ft)
I assume your talking about install step #4 from these instructions.
Removing and Installing a Hub Unit Bearing.
"Install the axle nut. Tighten the nut
to the vehicle manufacturer’s torque
specification using a torque wrench. An
impact wrench is not recommended
because it does not reliably impart the
proper torque."
