alignment headache
Old Mar 8, 2011 | 08:05 AM
godiving's Avatar
alignment headache
I installed a leveling kit on my 06 Supercrew FX4 over a year ago had it aligned and everything was great. last week I bought a new set of tires (33x12.5) which are the same diameter as i was running before just a little wider. I had the shop that i purchased the tires from do the alignment. I have taken it back 4 or 5 times within a week for it pulling to the left. cam kits have been installed it just still pulls left .
Old Mar 8, 2011 | 08:13 AM
RandomHero34's Avatar
take it somewhere else. and have the original shop show you the print out of the specs after the alignment.
Old Mar 8, 2011 | 08:14 AM
Big_Smokey's Avatar
are you a nascar driver? sorry to hear about that. I had no problems with my 06....shocks.....balljoints? I dont know much about aligning a vehicle. Didnt know if any lf that could cause your problem.
Old Mar 8, 2011 | 08:18 AM
godiving's Avatar
I am going to a different shop today. they showed me print outs where they said it was in spec. but if it is in spec it should drive straight was my argument. yes i did feel like i was in a nascar race .
Old Mar 8, 2011 | 08:20 AM
tradosaurus's Avatar
Moment Pwease.
I see 3 possibilities:
1) The truck is not able to be aligned
2) The shop is not capable of performing an alignment
3) The shop is not performing an alignment (but saying they are).
Old Mar 8, 2011 | 08:22 AM
godiving's Avatar
I go for number 2 and 3 . the truck drove straight before the tire swap
Old Mar 8, 2011 | 10:07 AM
you have to be careful about this one. a lot of places will do this and still give a print out.
Old Mar 8, 2011 | 07:43 PM
Do like I did last week and go back there while they're doing the alignment.
Old Mar 8, 2011 | 07:56 PM
quackrstackr's Avatar
Then you may have a bad or underinflated tire.
What tire did you go with, by the way? I've seen on here that some guys are reporting a pull to the left after installing Trail Grapplers.
Old Mar 8, 2011 | 08:53 PM
godiving's Avatar
trail grapplers is what i went with. They said that they cross rotated the tires the first time i took it back . I dont know . I have an appointment with another shop in the morning.
Old Mar 8, 2011 | 09:33 PM
check this out.
several more like it out there as well: https://www.f150online.com/forums/4482211-post9.html
Old Mar 8, 2011 | 09:45 PM
godiving's Avatar
that is crazy that you linked that thread . I had just emailed him about his tires. i ran the terra grapplers for about 60,000 miles before i swapped to these tires and had no problems.
