Tire Size
Tire Size
Will a 33" (305/55/20) Nitto Terra Grappler fit on a 2007 4X4 Lariat F150 WITHOUT leveling kit or lift kit?
I found a good deal on some 20" Chrome XD Spy's with the 305/55/20 Terra Grapplers with TPMS sensors for $1000. The tires have 10k miles on them and wheels are in perfect conditon.
These are coming off of a stock 2009 F150. Will the TPMS and fitment work for my 2007?
Backspacing on OEM 20"s, which are 8.5" wide, is 6.5". The backspacing on 7.5" wide rims is 6". With a 4.53" backspacing on a 9" rim, the centerline of the wheel is going to shift 2.25" outboard from the stock set up. That's way too much, IMO. You may like that look. You might experience some rubbing.
Since the 2009s have the same stock offset, you might want to ask him if he has pictures of the tires and rims on his truck. That should give you a good idea how much they stuck out beyond the fenders.
