Problem with Headlight Replacement bulbs...Help!!!
Old Jan 23, 2011 | 03:53 PM
maury18's Avatar
Hello,
My son, bought some HID Xenon Bulbs for his 04 F 150 FX4 off ebay. They are H13. They fit in the hole, but they will not turn clockwise to lock in. I put alot of pressure on them and they will not move. I am not sure if it is the bulb or if i am doing something wrong...Any ideas?
Old Jan 23, 2011 | 08:20 PM
MGDfan's Avatar
Originally Posted by maury18
Hello,
Hi & welcome!
1. Return the cheap bulbs - as you can see, they can arrive defective / mis-labelled.
2. Never put HID's in stock housings - it is both illegal and can blind fellow drivers - not cool.
3. Example of how to do this properly: https://www.f150online.com/forums/20...-retrofit.html
4. Have yer son do some research first: https://www.f150online.com/forums/ar...ns-v-hids.html
5. We have a new Lighting forum, FYI: https://www.f150online.com/forums/il...-lighting-131/
6. Why are you posting, and not yer son?
7. Good luck.
MGD
Old Jan 23, 2011 | 09:43 PM
DarkShadowSTX's Avatar
Well put MGD!
The fact that the bulbs don't fit is just the truck telling not to run those cheap crappy bulbs.
Old Jan 24, 2011 | 10:04 AM
bossman15's Avatar
Make sure you used the locking adapter piece most HID kits come with. It has a little red grommet on it.
