bed size
Old Jan 20, 2011 | 03:08 PM
stlhooked's Avatar
bed size
Does anybody know the width of a 2004 xlt regular cab off hand?
I'm not able to measure mine at the moment...
Thanks, Darin
Old Jan 24, 2011 | 12:54 PM
mkosu04's Avatar
found this online... can't verify the accuracy
DIMENSIONS
Wheelbase (in.) 138.8
Length (in.) 222.3
Width (in.) 79.5
Height (in.) 75.3
Overhang, f/r (in.) 38.7/48.2
Track, f/r (in.) 65.4/65.4
Minimum ground clearance (in.) 8.9
Ride height (in.) 37.0
Load lift height (in.) 35.5
Bed dimensions LxWxH (in.) 78.8x65.2x19.6
Approach/departure angles (degrees) 24/20
Breakover angle (degrees) 19
Weight (lb.) 4,980
Base weight distribution, f/r (%) 61/39
GVWR/GCWR (lb.) 6,000/12,000 (est.)
Max Payload (lb.) 2545
Max towing capacity (lb.) 7700
Fuel capacity (gal.) 24.5
http://flippedbits.net/F150/f150.htm
