Supposed to be a snowy night in GA
Now haven't you been watching Channel 2? Didn't they say to stay off the streets unless you have to be out there?!?!?!?!? Haha! Down in Lagrange we got a little sleet and a thin layer of ice. I was really disappointed considering the 2-4 inches of snow forecasted.... You guys lucked out!!!!
It also helps if you are used to it and know how to drive in it.
Haha, why not? I've driven my non lsd 2wd is waaay more snow than that. Right tires and weight in the bed are all you need.
So checked around this morning and all fuses are good. Switched a couple of relays that were able to switched and nothing has changed. I still get a flicker of 4wd HI. LOW is fine. I hear a tick when I switch to 4wd HI like it is trying to kick in but no clunk. Because of the LOW working I'm thinking it may be the solenoid (which I need to change to new model anyways) or transfer case motor. But would the motor work in LO if it was shot?
Can't tell you how much I appreciate this forum. Next comes the spark plugs
