Does your truck hunt/stutter at idle?
My truck has been doing the same thing for quite some time. Do ya'll have the same rough idle when even pressing lightly on the gas for little while until it gets into the higher RPM's? One day my truck will do this and the next it won't. Although it does seem to eliminate itself once the motor warms up, and by that I mean completely warms up.
Edge Evo confirms the drop in RPM when the shudder occurs of about 25-60 RPM depending on the shudder.
COPS should be here this week and they will be changed out next week. I'm also having Ford check my fuel injectors and the new plugs to make sure they were not affected.
mine goes away as soon as you press on the throttle. Mine also does it cold or warm with no difference. It also is happening in neutral, reverse, drive etc. Less so in neutral as the RPM is higher for the idle when not in gear.
New COPS go in on Wed and dealer will be checking my plugs and injectors for any issues. I will let everyone know what the outcome is.
