starting isssues
Old Dec 18, 2010 | 10:37 PM
cboham30's Avatar
starting isssues
My truck has been acting up. about once a day i go to starrt it, and it wont start. I have to put it nuetral to start it. Which starts fine everytime. I figure it was some kind of switch with the shift mechanism. Anyone have the issue
Old Dec 18, 2010 | 10:48 PM
the_cosworth's Avatar
So does it not turn over? If it turns over how does it sound? Can you drive it if you get it started?
I am wondering because if you put it into neutral you would be disengaging the driveline so if there is a seizure in the driveline that would cause it to not spin fast enough
Old Dec 19, 2010 | 10:05 AM
cboham30's Avatar
No it doesnt turn over at all. If i turn the key on all the power and gagues, everything comes on like normal, But if i turn the key all the way nothing happens. So if i put it in nuetral it starts just fine. Then i can turn it off and it will normal lets just say 10 time in a row. Then all the sudden it will do it again
Old Dec 19, 2010 | 10:47 AM
Is it an auto? I am going to say there is something wrong in the tranny.
Old Dec 19, 2010 | 04:28 PM
What kind of "truck"? I'd assume it's a Ford, but you haven't given us any additional information.
Neutral safety switch, otherwise known as the MLPS (manual lever position sensor).
Old Dec 19, 2010 | 10:56 PM
cboham30's Avatar
its a 05 screw f150 4x4 5.4 88,000 miles
