swapping OEM heated seats in a lariat?
My 05 Screw lariat didn't come with heated seats. I found a great set of 08 Lariat SCREW heated seats from a salvage yard. Since mine is a lariat with leather and the Electronic climated control. Should I just beable to swap the seats and the control panel below the h/ac controls with the switches? Does anyone know if the truck is wired already to do this mod as a plug and play?
thanks,
thanks,
I would agree - I can't say for sure that it's wired, but in my 06 Lariat I wanted to add the power pedals assembly. My truck did not come equipped with them so I bought a set from salvage and found that indeed it was wired for them. All I had to purchase was the switch for the dash. My impression is all Lariat's carry all the wiring for all the options- some just aren't used.
Help with this wring please
ok, I got the seats and I started on the passenger side. My truck has a manual seat on pass side and power on the drivers side, (non memory, and no heated). The seats I bought are heated, power driver and passenger. From the picture the plug circled in red was not on my manual seats. Also the wires I marked with a yellow x and line is not on my wire harness. The rest of the harness is there. I borrowed this pic from anothe post but it is the same as my seat I just bought. What is the plug circled in red for and if I go back to the salvage yard and get the harness marked with a yellow line and x do you think it just splices into existing wires in the loom? Any help of diagrams of what the missing wires goes to or if I can splice into what is already there is appreciated. I haven't looked at the drivers side yet but since my current is already power I assume all the plugs will be the same on that side. Thanks guys.
can you pull up the carpet on the salvage yard truck and follow the wires? I imagine it will be plugged into something on the other end. Near the new switches maybe?
It's part of the wire loom so I don't think that will help. I hope someone can help me out with what the plug is for? If it's just to make the power part of the seat work, I should be able to jump wires from the drivers power seat and have the power part going. What I bought the seat for was the heated part though. Does anyone know if the heated power is in this plug or one of the other 2 pictured?
thanks,
thanks,
guys, it looks like a bit more than I'm gonna tackle. I think I'll go the aftermarket seat heater route instead. If anyone wants a great pair of heated memory seats in tan, I listed them in the classified. $250 for the pair. thanks for all the info.
