Change brake pads, now problems, help
Old Dec 13, 2010 | 11:33 PM
symon_say's Avatar
I change my brake pads about 2 weeks ago, as soon as they where change i can hear a humming sound, i get back to the shop, they check everything, and everything looks fine, but the sound was still there.
Then my truck start doing a sound when cornering, not all the time, it was like something was hitting the wheels with the spin, i just discovered that one of the bushing in the stabilizer links was not there, that's an easy fix.
But tonight the truck start doing a sound when braking at low speed like abs, engaging and after the second time it did it, ABS light is on.
I'll try to read the code tomorrow, but are there any common problems related to brake pad changes, i use Wagner pads, that are recommended in here by a lot of member.
Thanks.
Old Dec 14, 2010 | 12:53 PM
mkosu04's Avatar
if there is a humming sound then it sounds like your brakes are dragging. Did they clean and grease the sliders?
Sounds like they also might have screwed up your ABS sensors...
