9000mi remaining on warranty
OK, I have just over 9k left on warranty for my '05 F150. I'm thinking I should bring it in to dealer and have it 'gone over' before warranty expires.....
Any suggestions on what to have checked? I'm thinking have transmission fluid /filter and differentials checked...
take it in for an oil change when it's due, they have to do their "full circle inspections" for no extra charge. they'll take a good look over your car, but just a generic inspection unless you tell them something specific you need checked out.
warranty?
Usually a complimentary 32 point inspection is all you'll get unless you actually have a maintenance issue. As a service manager I always had customers come in and all we could do is a free 32 point inspection.
I recommend looking it over yourself and saving a little gas money.
Check the following: Ball joints, tie rod ends, steering rack for leaks or damage, brake pads, rotors, front wheel bearings, brake fluid leaks, shocks & struts for leaks, engine and trans for leaks, rear diff for leaks, pull diff plug and check for excess shavings, radiator for leaks, coolant fill/overflow tank, wiper fluid tank, driveshaft u-joints, window and door seals for leaks, oil change and fuel filter replacement.
