2008 F150 Remote Start System MisInformation
Old Dec 8, 2010 | 01:49 AM
Jeffsaflyer's Avatar
Hello,
I want to go the OEM route with a Remote Start System for my 2008 F150 Lariat.
My Ford Dealer has not been able to provide all the information I need to make a decision on which of the alleged three OEM Systems to install.
In the research I have done, there is the Bronze System which is basically a plug-and-play One-Button Start System only and uses a separate Remote.
The Silver System which is the Start System along with the Panic, and Door Locking/Unlocking Functions, and only one Remote does it all.
And the Gold System which is the Silver System with the addition of a more advance Alarm System with a single Remote.
I am not really interested in the Gold System, so let's talk about some conflicting information I received about the Bronze & Silver System.
I was told by my Dealer that the Silver System was discontinued and there is only the Bronze & Gold options.
I don't have a problem with carrying an extra Remote with the Bronze System, but no one can tell me what the approximate Range is, and if it uses a Remote Antenna or not.
The Silver would be ideal so that I would just have the one Remote, but supposedly it is not available, and my Dealer said that when it WAS available, that there were alot of problems with the System and did not recommend it anymore.
I looked at the Ford Parts Website and that information is a little confusing also. They have several listings for Remote Start Kits.
This sort of situation is a little challenging for a small town Dealer. I had a couple of buddies that had them install Aftermarket Systems and they lost about half of the OEM Functions, Entry/Exit Lights, etc. So that is why I am staying with a simpler OEM System.....hopefully.
Thanks for your comments & information to help me with this.
Jeff
Old Dec 8, 2010 | 08:45 AM
06bluemeaniexl's Avatar
If you want the silver system, I have one sitting in my garage. I was going to install it but decided to get the Viper smart start system instead. I could sell it to you for a reasonable price.
Old Dec 8, 2010 | 10:28 AM
Huitt24's Avatar
I have a code alarm 670 installed on my truck and all of the OEM functions still work. Code alarm I believe is the manufacture for the Ford systems. I use a different remote than the stock one but it unlocks/locks and starts and has panic. My oem keypad entry will arm and disarm the system also which was a big plus. You can talk to Travis at KCautosound, he does a lot of install at the Ford dealerships along with power lock and window conversions for his local dealer. He also will help prewire the alarm for your vehicle and give you color step by step instructions.
Old Dec 8, 2010 | 10:33 AM
NOLAGT's Avatar
Is that the one that you can use your Iphone to start it? Do you use it like that...if so does it work well?
