Need Fuel Injector Help for My '05
Hey guys, can someone help verify the correct part number for new fuel injectors for my '05? On Rockauto.com, they show two MotorCraft part numbers but no other info.
MOTORCRAFT Part # CM5138
Ford 5C3E-9F593-DB {#5C3Z9F593DC, CM5091}
$26@ (2005-2006)
and
MOTORCRAFT Part # CM5179
Ford 9L3E-9U509-BA
$41@ (2005-2007)
I am assuming the more expensive ones are the current injectors used (the model years are a dead giveaway!), but can anyone confirm?
thanks for any info!
$26@ (2005-2006)
and
Ford 9L3E-9U509-BA
$41@ (2005-2007)
if you goto o'reileys and ask for the BWD brand injector, it is the exact same thing as what is in your truck now. as a matter of fact if you look at your old one and the new one side by side they have the same markings, numbers and all. and if you are lucky you will get one like i did where they forgot to dremel off the ford logo on the one i got from o reileys
