Radio Startup Issues
Old Oct 11, 2010 | 04:29 PM
CANES676400's Avatar
Every so often when I start my truck the radio is on a random AM station and the clock is on the wrong time, the cd player also cycles through all 6 discs. I thought it was a loose battery cable but wouldnt that also reset my presets. Do anybody know whats happening?
Old Oct 12, 2010 | 09:24 AM
06 So Comfort's Avatar
Disconnecting the battery doesn't kill your presets any more. Guess they got smart and went to flash memory. You are correct to treat your problem as an intermittant loss of memory voltage.
Old Oct 12, 2010 | 09:50 PM
how do i go about fixing it
Old Oct 12, 2010 | 10:29 PM
fatty4x4's Avatar
sounds like the backup power fuse is blown. I would check the fuses to start.
Old Oct 13, 2010 | 02:42 PM
Loose connection in radio power cable/plug, loose fuse, battery cable going bad, battery itself starting to go bad, ignition switch, etc. Look for an intermittant loss of memory voltage to the radio.
Old Jan 22, 2014 | 01:24 AM
LittleTow's Avatar
Did they do that in 03 or later?
