gryphoon questions.
gryphoon questions.
id like to get the pcm reflash for my truck that stops the flare up in rpms between certain shifts, but i see this messes with the gryphoon.
i just want the normal gryphoon right not the cs one
this one
http://www.powerhungryperformance.com/_gryphon.shtml
do i need to do a tune? all im looking to do is make the trans stop being so sluggish and correct tire size when i get tires.
any horsepower gains with 87 octane tunes or is the advertised performance gains on 93 octane?
does it come with the dash piece i need to hold it or is that seprate
how hard to install?
this one
Gryphon from PHP, comes with everything you need to install including the dash pod. Installation is super easy, can be done in 5-10 minutes. The canned tunes are all better than factory. I suggest running level 2 (89oct) or level 3 (91-93 oct), both will drastically improve your shifts. If you have would like to get custom tunes thats always an option too.
this one
this one
j/k ... 'yes' to both, lol
MGD
If you do not already have one, get the TSB reflash done, and supply that new strategy calibration hex code to PHP. They will build on that factory calibration.
MG 'effin D
MGD
oh it works like that, i thought you had to do a gryphoon and no reflash. i was planning on getting it reflashed anyways, so i would just tell php i have the reflash and they build me a tune on that?
anything else out there i should be doing to my truck along the lines of this reflash, since i didnt know it existed until i googled for it?
Nothing else you need to do - just take it in & git 'er did
MGD
