Window Regulator: This is gonna be fun...
My window fell into my door today after the oh-so-famous POP. Going to the dealership to pick up the new assembly tomorrow to fix it myself. But shortly after I remembered that my door hole is sealed up and looks like this currently:
Should be a fun project stripping all the Butyl off there, especially since the weather is just now turning cold.
These regulators seriously SUCK.
Well I got it done. Besides the 1.5 hours it too me to remove a bunch of Butyl deadener and the Aluminum flashing I used to seal the door as a speaker enclosure, the install of the window regulator is a piece of cake. I actually did not re-install the flashing as I removed the midwoofers and will be fiber-glassing some kick-panels for them instead.
Don't let the dealer rape you on this change, it is super easy. Once you get the door panel off all you need is a 10mm socket and 15 minutes of time. Just be sure the tape the window to the top of the door so it doesn't fall back down.
