Drive Shaft HELP!
Old Sep 29, 2010 | 02:08 PM
05_F150's Avatar
Drive Shaft HELP!
Im sure there has been many topics on the rear end clunk but I cant find a write up on how to fix it.. Do I just mark the index on spline, drop the carrier and un-bolt the u joint and pull the shaft out of the tranny and fix? Someone please help and tell me the do's and dont's in putting AFTE (teflon) grease on my shaft spline? thanks alot in advance Jay... its a 2005 2WD supercrew with 5.4 and 2 piece shaft if that helps
Old Sep 29, 2010 | 05:19 PM
05_F150's Avatar
im sure almost anyone with a 04 up f150 has had this problem but yet no help? thanks people
Old Sep 29, 2010 | 06:22 PM
Mine doesn't clunk, but I can tell it needs to be greased.
Neither are an F150, but should give you an idea.
http://www.eurekaboy.com/f250/slipjoint.htm
http://www.frontiernet.net/~jmray/F250SlipYoke.htm
Old Sep 30, 2010 | 10:10 AM
05_F150's Avatar
Thanks, ill be doing this Saturday.. Driving from Fla to Tennessee so I wanna make sure everything is tighten up
