HELP :/ Whats this Noise! ( Video Diagnosis )
Old Sep 26, 2010 | 08:56 PM
cmolina07's Avatar
Originally Posted by Stealth
Rock Auto dot com.
stealth does a 4wd bearing fit on a 2wd because thats all i can seem to find , which is hard for me to believe
Old Sep 26, 2010 | 09:07 PM
The rotor for a 2wd has the wheel bearing in it. That's what you need.
Old Sep 26, 2010 | 09:32 PM
cmolina07's Avatar
ahhhhh ok thank you for your input sir
would this do the trick?
http://www.stylintrucks.com/part.asp...7&scid=FROOGLE
or is that unessicary to buy the whole thing?
Old Sep 27, 2010 | 06:35 AM
Moderator Bluejay has been using Raybestos brand with good results.
Old Oct 1, 2010 | 01:10 PM
cmolina07's Avatar
so i got the parts... did the install myself ... took about 20 min total to do and whaaalah...
the sound is gone and the truck drives straighter and smoother
Thanks for the help stealth
Old Oct 2, 2010 | 12:21 PM
Jakejdt's Avatar
Mine made the exact same noise starting 3 days ago....knew what it was, since the bearing had been quietly grinding for a while. And the sound.....got a 03 Chevy Silverado HD 4X4 that's made the same noise all 3 times the front driver side bearing has gone out in the past year. Pretty much the same bearing setup on that, except it truly is a one piece assembly. Pressing new bearings into the 4X2 F150 hub right now.
