Transmission coolers
Old Jul 25, 2010 | 06:36 PM
weazel's Avatar
Registered User
Hey, looking to add a larger trans cooler. I saw a cooler in the past that mounted to the factory mounts does any one have a link to that. if not what have some of you other guys done to add larger trans coolers.
Old Jul 25, 2010 | 09:56 PM
weazel's Avatar
Registered User
no one?
Old Jul 26, 2010 | 11:25 AM
Most of the larger ones that I've seen or read about people doing are for the F250.
Sorry no other info or links.
Edit.
Ford Part numbers.....
26-row 5C3Z-7A095-CA
31-row 5C3Z-7A095-CB
The 26 row is just as efficient as the 31 and cheaper.
Old Jul 26, 2010 | 05:49 PM
Fuelonempty's Avatar
You could either install the Superduty trans cooler, or any of the big aftermarket trans guys.. they even offer it with an optional fan. For added safety, I usually add an inline transmission fluid filter as well. custom brackets are really easy, plenty of factory holes to use. that sounds strange I know lol.
Old Jul 26, 2010 | 10:09 PM
avfrog's Avatar
You can also add some fans on your existing cooler, if your up to some fab work.
Old Jul 27, 2010 | 08:02 PM
COCIMitch's Avatar
I put a larger (2qt.) / deeper pan on mine and it's running several degrees cooler.
I think PML is who makes it. Verified it ran cooler by monitoring my edge before/after.
Old Jul 27, 2010 | 08:14 PM
weazel's Avatar
Registered User
i actually have the mag hytech deep dish pan but my truck runs warmer due to the supercharger and larger wheels and tires. i just picked up another cooler i plan to add it the weekend. thinking about adding a fan to the cooler too.!
these 110+ temps are hard on the truck.
Old Jul 28, 2010 | 02:07 PM
http://www.troyerperformance.com/cgi...gno=PPI-ATCKIT
