Plug Change Successful So Far.....
Old Jul 27, 2010 | 05:49 PM
  #31
88rxn/a's Avatar
so far, this is the cheapest i could find the plugs...
http://k-mansparts.com/items/f-150/i...rt_id=13297429
for me its $69.98 shipped for all 8.
anyone have a cheaper place?
Old Jul 27, 2010 | 06:48 PM
  #32
jimmyv13's Avatar
Anyone want to sell their lisle tool?
Old Aug 1, 2010 | 07:59 PM
  #33
danjkelly's Avatar
Question Those who accomplished the plug change
I'm ready to do my 07 FX2 with 52000
Everything look accessable BUT the passenger side rear.
Can that computer be taken down without problems, what is the Big A$$
harness over the COP?
I'll use a bottle of seaform too and soak it with PB Blaster
Any other trick to try?
Stealership said to use quick impact to break plug free.
anyone else do that?
Old Aug 1, 2010 | 08:13 PM
  #34
Do not use PB Blaster. Use Carb cleaner. Take the PCM loose and shift it to the side out of the way.
Old Aug 1, 2010 | 09:52 PM
  #35
fx4renegade08's Avatar
I have an 04 and changed the plugs at 85,000 miles, and 6 out of 8 broke on me. I did use penetrating oil also.
Old Aug 1, 2010 | 09:53 PM
  #36
Should have used carb cleaner like the TSB says.
Old Aug 1, 2010 | 10:24 PM
  #37
XPerties's Avatar
Not always true. Ive come to find out after reading post after post on this board and others, a lot has to do with the person doing the work.
Anyways, I sea-foamed my truck 2 weeks prior, ran carb cleaner through tank of gas, used PB Blaster after backing out 1/4 turn then let sit for 35 minutes at which point I tightened, back out, tightened and then backed out at 1/4 turn (click on the ratchet) and that was done on a cold engine although it was 104F that day.
Worked fine:
Old Aug 2, 2010 | 10:25 PM
  #38
emrdux's Avatar
Like XPerties I used PB Blaster and took my time. Only broke one. F the TSB - its written by the same company that gave us this lousy plug design (not to mention they hope to sell a few extra cans of their carb cleaner in the process).
BTW - these plugs had 110k miles on em.
Old Aug 3, 2010 | 10:21 AM
  #39
bdavid's Avatar
i am surprised that more people don't try the Kroil. It is a penetrating oil that actually dissolves carbon deposits. It even says it on the bottle. When i removed my eight plugs the carbon was actually dripping off of the plugs. is there some bad info on the Kroil that i don't know about???
Old Aug 3, 2010 | 01:16 PM
  #40
In the first TSB, Ford said to use Kroil. In the second TSB, they changed to carb cleaner. It was thought that it was probably because Kroil was more of a lube and not pure solvent. Personally, I think a combination of the two would be best. Start off with Kroil and once you get them broken loose, switch to carb cleaner.
Old Dec 2, 2010 | 04:34 PM
  #41
The Pig's Avatar
Maybe that is the plug for the early 2008 and up, the new head design.
SP-515 is the latest recommendation from Ford for our problem engine. It replaces the SP-507.
Old Dec 2, 2010 | 07:24 PM
  #42
No, the 515 is a double platinum, the 507 is a single platinum. They both are the so-called "improved" design.
Old Dec 2, 2010 | 07:46 PM
  #43
x2mosg's Avatar
Can someone give me the item/part number for the Lisle tool? I've been to a local parts store and I'm not sure they understand what I'm looking for. I'm gonna change mine soon, probably after January on a warm day, if there is such before April.
Thanks for the help,
David
Old Dec 3, 2010 | 06:15 PM
  #44
http://www.tooldiscounter.com/ItemDi...ookup=LIS65600
I haven't looked yet, but check the forum classifieds, maybe someone has one they want to get rid of.
Old Dec 3, 2010 | 11:22 PM
  #45
x2mosg's Avatar
glc,
Preciate that. That saves some time and a headache, at least aquiring the tool. LOL!! Based on my luck, I'm sure the plugs are gonna be a major PITA, but I expect it so....
Any particular brand of carb cleaner that ya'll recommend? I keep PB Blaster on hand, so got that covered.
Thanks,
David
