beilstein insall... pricey?
Old Jun 14, 2010 | 12:06 PM
Crstfr's Avatar
i just got back form 4x4 parts here in austin tx... 655 out the door for the install of the Beilstein 5100 HD's...... front and back plus fluids....
this about right....
he mentioned an 85 dollar "look at"... where the guy takes one hour labor and looks over the entire suspension, to tell whats wrong.. i think this comes out of the total cost~..
any input , or locations that do as good a job for cheaper??
thanks guys,
chris
Old Jun 14, 2010 | 01:17 PM
I'm in a low labor cost area of the country - I just had shocks done by a local muffler and brake shop. They don't sell shocks, they tell you to bring a set in and they charge $25 a shock to install them. I also checked with the local Goodyear shop, they sell shocks at a nasty markup and charge book labor to change them, which would have been about $35 a shock for my truck. I bought Gabriel Ultras at Autozone for $34 each, Goodyear wanted $68 each for the same thing.
I don't know if book time is higher or lower for your truck than mine - I have a 2wd OBS.
Old Jun 14, 2010 | 01:18 PM
Dog'em's Avatar
Does that $650 include the shocks ?
Old Jun 14, 2010 | 01:38 PM
thanks guys,
chris
what fluids do you need to do shocks?
Bring it to me and ill do the four shocks for 175.
Old Jun 14, 2010 | 01:50 PM
greencrew's Avatar
Pricey on a 2005, but not pricey on a 2003. If you price includes the shocks, then it is a good price.
Old Jun 14, 2010 | 01:52 PM
Crstfr's Avatar
yes... fronts with struts, and back... plus all fluids and install.....
Old Jun 14, 2010 | 01:53 PM
Crstfr's Avatar
lol... man i'd let ya!.... i guess the lube the 4x4 and check all the joints and bushings.. i'm thinking along the lines of that...
i'll be sure to find out when i pull the trigger!...
Thanks Patman~
Old Jun 14, 2010 | 01:54 PM
Crstfr's Avatar
that it does... thats the 2 back shocks, plus the 2 struts in the front....
i'll probably have to dump in another 200 for bushings, ball joints, and all that fun stocker stuff that needs to be replaced after 103k....
Old Jun 14, 2010 | 02:16 PM
yea you're probably gonna need upper and lower ball joints too at 100k+
Old Jun 14, 2010 | 04:21 PM
Crstfr's Avatar
yeah ... i figured as much~....
Thanks for the reply`.. i'm sure i'm close to 800 after its said and done, but should run like the day i met her~i hope!
chris
Old Jun 14, 2010 | 09:46 PM
greencrew's Avatar
Should run better with those fancy shocks.
Old Jun 15, 2010 | 02:24 PM
The 04 went to struts? That explains a higher labor cost.
Old Jun 15, 2010 | 04:39 PM
yes coil mounted on the strut. Aka McPherson Strut suspension
Old Jun 15, 2010 | 04:54 PM
GTRider245's Avatar
Yeah, so why is everyone saying the 04+ trucks should be LESS? It's the other way around.
I was quoted around $200 for install on my 2005 here. Didn't seem to bad at the time.
Still not sure what "fluids" you are talking about.
Old Jun 25, 2010 | 02:26 PM
Crstfr's Avatar
5100's are backordered...grrrr.r.. till mid July here in austin tx.... just called to setup an appt.
149 fronts
75 backs
300 install just on shocks....says they have to compress to install....ok...
... ...this that..831......for that....
now that didn't include alignment.....nor new upper and lower balljoints and bushings.. if needed.....
sound right?
