Check Fuelcap
Check Fuelcap
I have a check fuelcap message on my 2004 supercrew. Anyone know what the problem might be? I have taken it off and tightened it multiple times but it keeps coming back.
The Pcm won't run the test if there is more than 3/4 or less then 1/4 fuel in the tank. It has to go through a few drive cycles with out an issue. Or it could be a major leak in the vapor recovery system.
Since you have a gryphon, why dont you reseat your cap, clear the code and then see if it comes back verses waiting on it to clear itself. After clearing the code if it comes back on, go get a new cap.
Check the o-ring in the cap. Then start checking the vac lines on the tank and vapor system, maybe the charcoal canister. The canister vent solinoid being stuck open might give you the same code.
Is there a code? If so what is it?
