Dash Wiring Change Need Help
Old Jun 8, 2010 | 03:43 PM
HotBlue05SCREW's Avatar
I have a 05 F150 Supercrew XLT.
Got a deal on dash and cab wiring from a 05 F150 X-Cab Larait. Changed all dash wiring and fuse box last night and everything went great.Finished up little odds and ends this morning and went for a drive. Now the ABS light is on and the battery went dead and the motor has what seems like a different sound and doesn't seem right when you throtle it up.Where to start what would be so different . Any help would be great .
Old Jun 8, 2010 | 04:16 PM
l337viton's Avatar
I'm guessing you must have wired something up wrong. Seems odd that your battery would die. Did the battery die overnight? The change in motor might be due to your PCM having to relearn its settings since it lost power due to the battery.
Just thoughts... Good luck!
Old Jun 8, 2010 | 08:06 PM
It almost sounds like a back fire , or air blowing back in throttle body.Searching for the ABS problem,and no it started right up this morning and than didn't a little latter. I'l planning on installing leather seat covers, heated seats, and adding power pass seat, factory amp , factor lighted visor with hopefuly home link.First stage was the dash wiring so will have to work out the buggs on the dash first.
