4low question
Old Jun 1, 2010 | 02:48 PM
TexasTomFX4's Avatar
4low question
I have a 2005 FX4 i have recently changed out the hub and the cv joint, once I had the truck in the air I turned on the 4low 4x4 and only three of the tires spin? Is that normal? I thought if I had it on 4low all the tires/wheels move? Can somebody please help?
Old Jun 1, 2010 | 03:09 PM
mdhawkin's Avatar
You have limited slip diffs. 4low changes your gear reduction through the transfer case but does not affect your differentials. If you want all 4 to always turn you will need lockers.
Old Jun 1, 2010 | 03:36 PM
That's great to hear. Thanks you have put my worries to rest.
Old Jun 1, 2010 | 04:33 PM
mav015's Avatar
yea ur good
Old Jun 1, 2010 | 04:47 PM
Block the front wheel that's turning and the other front wheel should start spinning. The front diff is an open diff.
Old Jun 1, 2010 | 06:13 PM
minus_13's Avatar
Yep... open dif. up front... sounds like it is working correctly.
Old Jun 1, 2010 | 09:13 PM
mdhawkin's Avatar
Sorry I did give a tid bit of incorrect info, open dif up front limited slip in the rear. Thanks for the correction guys, dont know what I was thinking.
