E-fan Question
E-fan Question
i just got my e-fan installed.... all works good
just that the truck now runs 6 deg hotter then it did before
was running 192 (used edge to check this)
now with the new fans it run 198
i have two 15" fans
when i run only one it runs 198
when i run both it runs 198
i have adjusted the controlers all the way
and no change...
i have two 15" fans
and no change...
yes they are going the right way...
i have heard that the 5.5 likes it between 200 210.
but then why was the truck running 192 from the factory
and why can i NOT get the e-fans to run below 198..
i have two 15" fans
and no change...
i have two 15" fans
and no change...
Yeah, tell us what controllers are you using and which fans? Do you have a way to check the temperature at the radiator when the fans kick on? Where did you place the temperature probes? Did you wire one fan into the A/C clutch so that it turns on when you use your air conditioner?
the kit was from junes modified
thats all i know
good a great price on it...
wired both for the a/c and it all works fine...
no way to check temp other than the edge
probes are near the water inlet ( top pass side of rad)
thats all i know
