Changing radiator. Need to remove fan?
Old May 27, 2010 | 12:07 AM
Kwattro's Avatar
Can I change rads on my '06 FX4 5.4L without removing the fan?
Old May 27, 2010 | 12:32 AM
geobull90's Avatar
Ya you are going to have to remove the fan. Here is the procedure for removing the fan if you want it.
1. Drain the cooling system.
2. Remove the cooling fan and shroud.
3. Release the clamp and disconnect upper radiator hose.
4. Release the clamp and disconnect upper degas bottle hose.
5. Release the clamp and disconnect lower radiator hose.
6. Disconnect the transmission cooler tubes.
7. Remove the bolts, the radiator support brackets and the upper radiator insulators.
8. Remove the radiator.
9. Remove the lower radiator insulators.
10. To install, reverse the procedure.
If you have any questions on how to do any of these, write me and I will help you out.
Good luck
Old May 27, 2010 | 07:25 AM
Windsor's Avatar
Actually, I think you can. There's no way to get the shroud out without removing the fan, before you pull the radiator. But if you move the shroud forward, I think there's enough room to pull the radiator up and out. I don't know that it will be any easier.
Let me save you some grief. Get the right transmission line cooler removal tool before you start. Most line tools I was able to find of the appropriate line size would not fit. I had to make my own tool. If you can find one that works with the radiator mounted cooler lines, get it before you start.
Old May 27, 2010 | 10:17 AM
geobull90's Avatar
Here is the part number from ford for the transmission line cooler removal tool.
Part # ST2591-A
Old May 27, 2010 | 10:23 AM
jaymz's Avatar
I know I can on my Heritage F150: put shroud over fan; pull radiator straight up. The manual says youi have to remove the fan, but it's just so the Stealership can add time to the bill.
Old May 27, 2010 | 10:55 AM
Kwattro's Avatar
I ordered the line tool a few minutes ago. I'd like to get my ford racing rad installed before I start towing again. Thanks for the replies.
Old May 27, 2010 | 11:17 AM
geobull90's Avatar
glad i could help
Old Jun 22, 2010 | 05:38 PM
Kwattro's Avatar
Totally possible, all kinds of room once the shroud is loose. The FRP rad is a little more that 2x as thick as stock, bolts in 100% no issues and hopefully will make life a little easier when towing. Thanks all.
Old Jun 22, 2010 | 06:16 PM
weazel's Avatar
Registered User
i just installed my saleen radiator with out removing my FAN OR SHROUD! Its more then possible!
Old Jun 22, 2010 | 09:32 PM
ford norseman's Avatar
Ummm... Why make things more difficult than they have to be? Just remove the fan.
Old Jun 23, 2010 | 01:41 AM
Kwattro's Avatar
We didn't. Removing the fan would have been more difficult, and time consuming. There's absolutely no need for the extra space by removing the fan, it's a total waste of time for a rad change. Like I said, new rad is over 2x thicker and there was all kinds of extra room there.
Old Mar 22, 2011 | 01:27 PM
Intimidator317's Avatar
did ya'll flush drain the system or just the stock radiator???
motorcraft or zerex coolant???
how many gallons???
Old Mar 22, 2011 | 01:29 PM
did you get the line tool from the dealer...how much???
Old Mar 22, 2011 | 03:16 PM
http://www.amazon.com/Lisle-39960-Tr.../dp/B000TQ6P40
Old Mar 23, 2011 | 01:19 PM
will those also work for changing the fuel filter???...mine is 3/8...even though every parts store tried to sell me 5/16...but the 5/16 wrench I also bought then took back was able to get the filter off...next time I buy motorcraft...
if not will these work for both???
http://www.amazon.com/Astro-Pneumati...=2KSP96YKV6PY0
