Front leveling spacer and grille guard?
Old May 17, 2010 | 10:17 AM
Titan357's Avatar
if i use a front spacer between the body and the struts, will that mess the placement of my grille guard up?
Old May 17, 2010 | 10:40 AM
GTRider245's Avatar
Why would using a leveling spacer have anything to do with the placement of your grille gaurd?
You need to do some research. The spacer does not go between the strut and the body. Not even sure how that would be possible. Sounds like you are confusing a leveling spacer with a body lift. It goes between the strut tower and the coil spring.
Old May 17, 2010 | 11:08 AM
Titan357's Avatar
oh, well thanks.
Ill go look around.
Old May 17, 2010 | 08:30 PM
hllon4whls's Avatar
It will not affect the grill or the bumper. Its stretching the suspension, not a body lift.
If you look in your front wheel well, the spacer goes between the spring and the big steel "cup" that it rests in. It pushes the whole truck up not just the body.
