Tail gate lock.....
Old May 13, 2010 | 03:56 PM
Scotty Dog's Avatar
Tail gate lock.....
So my tail gate lock has never worked the key would not turn. So today I put some lube fluid in it and it worked it is now locked.... Now I cannot unlock it is ther a trick to it? It turns freely back and forth but will not unlock. Kinda hard to get the dirtbike in the back with it up..
Old May 13, 2010 | 05:51 PM
ab46501's Avatar
No trick. It sounds like yours has a problem. There is a panel on the inside of the tailgate you can remove. You should be able to access the back tailgate lock from there and unlock manually. Here is a link to where a guy added a power lock to his. It should give you an idea of what you are looking at. http://members.***.net/kinzerford/F-...gate_Lock.html
Old May 14, 2010 | 12:06 PM
Scotty Dog's Avatar
Thanks for the info ab46501, I took it apart today, there is a little plastic clip that acts as a guide for the lock arm, it had what I call a christmas tree pin on it, and it was not holding anymore, So I broke out my trusty Zap straps, best invention ever, I use them on everything.
