Can you identify these rims?
I am looking at a set of slightly used 20" rims and goodyear tires. I am trying to find out what the rims are.. the seller does not know.
Can anyone identify them?
Also the tires are 285/50/20's.. will these be fine for my 2005 supercrew Fx4?
I must admit, the second picture looks ALOT better. I did a good bit of searching and still can not put my finger on them. If I come across them, I will be sure to to let you know.
Thanks.. I am also searching all over the net. This is a challenge and I did not realize how many aftermarket rim companies there are.
He just had them put on this summer so they are not old.
I just want to make sure they will work for the 4wd. Based on the small cup (hub clearance??) I think they will fit fine.
I think I found them. EuroMax rims
I can't seem to find specs other than the 6x135 are 20"x8.5 with 35mm offset and will work for 4wd. These are the chrome version and I am looking to see what finish the ones I am looking at buying are.
Any ideas?
Any ideas?
